Normal Topic Remove Item (Read 3485 times)
Silvia88
Remove Item
Oct 7th, 2015 at 5:49pm
Hi, I remove a node from the diagram using diagram.getNodes.remove, then I went on method nodeDeleted and I need to take the link of the deleted node, how can I get it? because as I delete the node the link doesn't exit anymore but I must keep track of it
Re: Remove Item
Reply #1 - Oct 7th, 2015 at 6:45pm
You should get linkDeleted event raised first; try handling it to keep track of links.
Silvia88
Re: Remove Item
Reply #2 - Oct 7th, 2015 at 7:19pm
Thank you very much, it works  Smiley
