Normal Topic FlowChartX XML Documentation (Read 6541 times)
ThomasAccount
Jan 26th, 2016 at 5:12pm
I need to create a FlowChart XML out of an C#-CLR for later view. So my Question would be, is there an documentation on how to create a valid XML-File for the Flowchart X Control? E.g. which xml-tags are required and what for and which are not necessarily required?
Greetings
Re: FlowChartX XML Documentation
Reply #1 - Jan 26th, 2016 at 6:03pm
Instead of generating XML, you should be able to use the ActiveX Typelib importer of Visual Studio to import FlowchartX classes into your .NET application, and then use the control's API to build the flowchart and call SaveToXml. You might also check our native .NET library, you should be able to use it to build flowcharts and save XML files compatible with ActiveX control.
If you prefer generating XML, these seem to be the minimum required tags to load something -
<Diagram Version="17">
    <Nodes>
        <Node Class="std:ShapeNode" Id="0">
            <Bounds>10,10,100,100</Bounds>
            <Visible>true</Visible>
        </Node>
        <Node Class="std:ShapeNode" Id="1">
            <Bounds>210,10,100,100</Bounds>
        </Node>
    </Nodes>
    <Links>
        <Link Class="std:DiagramLink" Id="3">
            <Origin>0</Origin>
            <Destination>1</Destination>
            <Style>1</Style>
            <SegmentCount>1</SegmentCount>
            <Points>
                <Point>110,60</Point>
                <Point>210,60</Point>
            </Points>
        </Link>
    </Links>
    <Properties>
        <Bounds>0,0,1000,1000</Bounds>
        <DefaultShape>Rectangle</DefaultShape>
    </Properties>
</Diagram>
You can also add tags for Text, Brush, Shape, etc... Tags correspond to property names in our .NET API though, and not the ActiveX one - the ActiveX naming is somewhat different.
ThomasAccount
Reply #2 - Feb 9th, 2016 at 3:55pm
Dear Slavcho,
thanks for your reply.
I tried to generate the xml file and encounter the following problem:
I wanted to add a Caption to a Box and I used the <text></text> Tag for that. This worked out fine, but I was unable to add a line break in the Text.
So my question is, how can I add line breaks in captions for boxes in the xml-file?
Greetings
Reply #3 - Feb 9th, 2016 at 4:44pm
Dear Thomas,
We use white-space preserving XML parser; as long as the xml-builder library you are using preserves white space too you should be able to use plain CRLF sequence in the text to create new lines -
<Text>line 1
line 2
line 3</Text>
You might as well use XML amp entities to create the new-line sequence -
<Text>line 1&#13;&#10;line 2</Text>
ThomasAccount
Reply #4 - Feb 10th, 2016 at 12:56pm
Dear Slavcho,
Thanks for your support so far.
I generated the following XMl File:
<?xml version="1.0" standalone="yes"?>
<!--FlowChartX diagram-->
<Diagram Version="11">
	<Brushes Count="4">
		<Brush Id="0" Type="Gradient">
			<Angle>90</Angle>
			<Color1>#FFFFFF00</Color1>
			<Color2>#FF404000</Color2>
		</Brush>
		<Brush Id="1" Type="Solid">
			<Color>#FFC0C0C0</Color>
		</Brush>
		<Brush Id="2" Type="Solid">
		</Brush>
		<Brush Id="3" Type="Solid">
		</Brush>
	</Brushes>
	<AnchorPatterns Count="4">
		<AnchorPattern Id="0">
			<Id>Decision1In3Out</Id>
			<Points Count="4">
				<AnchorPoint>
					<AllowIncoming>True</AllowIncoming>
					<AllowOutgoing>False</AllowOutgoing>
					<Color>#FF0000FF</Color>
					<Column>-1</Column>
					<MarkStyle>3</MarkStyle>
					<X>50</X>
					<Y>0</Y>
					<ChangeArrowStyle>False</ChangeArrowStyle>
					<ArrowStyle>1</ArrowStyle>
				</AnchorPoint>
				<AnchorPoint>
					<AllowIncoming>False</AllowIncoming>
					<AllowOutgoing>True</AllowOutgoing>
					<Color>#FFFF0000</Color>
					<Column>-1</Column>
					<MarkStyle>4</MarkStyle>
					<X>100</X>
					<Y>50</Y>
				</AnchorPoint>
				<AnchorPoint>
					<Color>#FF00FF00</Color>
					<Column>-1</Column>
					<X>50</X>
					<Y>100</Y>
				</AnchorPoint>
				<AnchorPoint>
					<Column>-1</Column>
					<X>0</X>
					<Y>50</Y>
				</AnchorPoint>
			</Points>
		</AnchorPattern>
		<AnchorPattern Id="1">
			<Id>Decision2In2Out</Id>
			<Points Count="4">
				<AnchorPoint>
					<Column>-1</Column>
					<X>50</X>
					<Y>0</Y>
				</AnchorPoint>
				<AnchorPoint>
					<Column>-1</Column>
					<X>100</X>
					<Y>50</Y>
				</AnchorPoint>
				<AnchorPoint>
					<Column>-1</Column>
					<X>50</X>
					<Y>100</Y>
				</AnchorPoint>
				<AnchorPoint>
					<Column>-1</Column>
					<X>0</X>
					<Y>50</Y>
				</AnchorPoint>
			</Points>
		</AnchorPattern>
		<AnchorPattern Id="2">
			<Id>LeftInRightOut</Id>
			<Points Count="2">
				<AnchorPoint>
					<Column>-1</Column>
					<X>0</X>
					<Y>50</Y>
				</AnchorPoint>
				<AnchorPoint>
					<Column>-1</Column>
					<X>100</X>
					<Y>50</Y>
				</AnchorPoint>
			</Points>
		</AnchorPattern>
		<AnchorPattern Id="3">
			<Id>TopInBottomOut</Id>
			<Points Count="2">
				<AnchorPoint>
					<Column>-1</Column>
					<X>50</X>
					<Y>0</Y>
				</AnchorPoint>
				<AnchorPoint>
					<Column>-1</Column>
					<X>50</X>
					<Y>100</Y>
				</AnchorPoint>
			</Points>
		</AnchorPattern>
	</AnchorPatterns>
	<Environment>
		<Appearance>
			<AntiAlias>Default</AntiAlias>
			<BackColor>#FFDFDFFF</BackColor>
			<ActiveMnpColor>#FFFFFFFF</ActiveMnpColor>
			<DisabledMnpColor>#FFC80000</DisabledMnpColor>
			<BkgrImagePos>0</BkgrImagePos>
			<Font>
				<Name>Tahoma</Name>
				<Size>8.25</Size>
				<Bold>False</Bold>
				<Italic>False</Italic>
				<Underline>False</Underline>
				<Strikeout>False</Strikeout>
				<Unit>World</Unit>
			</Font>
			<SelMnpColor>#FFAAAAAA</SelMnpColor>
			<ShadowColor>#FF505050</ShadowColor>
			<ShadowColorAlpha>150</ShadowColorAlpha>
			<ShadowsStyle>1</ShadowsStyle>
			<ShowAnchors>2</ShowAnchors>
			<ExpandBtnPos>0</ExpandBtnPos>
			<SelHandleSize>9.000000</SelHandleSize>
		</Appearance>
		<Behaviour>
			<AllowLinksRepeat>True</AllowLinksRepeat>
			<AllowRefLinks>True</AllowRefLinks>
			<AllowUnanchoredArrows>True</AllowUnanchoredArrows>
			<ArrowEndsMovable>True</ArrowEndsMovable>
			<ArrowsSplittable>False</ArrowsSplittable>
			<AutoScroll>True</AutoScroll>
			<Behavior>3</Behavior>
			<ExpandOnIncoming>False</ExpandOnIncoming>
			<ModificationStart>0</ModificationStart>
			<PrpArrowStartOrnt>0</PrpArrowStartOrnt>
			<RecursiveExpand>False</RecursiveExpand>
			<RestrObjsToDoc>1</RestrObjsToDoc>
			<SelectAfterCreate>False</SelectAfterCreate>
			<SnapToAnchor>1</SnapToAnchor>
			<StaticMode>False</StaticMode>
			<ShowToolTips>False</ShowToolTips>
			<HighSpeedRouting>False</HighSpeedRouting>
			<SelectAfterPaste>True</SelectAfterPaste>
			<AllowUnconnectedArrows>False</AllowUnconnectedArrows>
			<MinimizeRouteSegments>False</MinimizeRouteSegments>
			<HitTestPriority>1</HitTestPriority>
			<SelectionOnTop>True</SelectionOnTop>
			<RoundedArrows>False</RoundedArrows>
			<RoundedArrowsRadius>40.000000</RoundedArrowsRadius>
		</Behaviour>
		<Defaults>
			<ArrowBase>0</ArrowBase>
			<ArrowBaseSize>20</ArrowBaseSize>
			<ArrowColor>#FF000000</ArrowColor>
			<ArrowFillColor>#FFC0C0C0</ArrowFillColor>
			<ArrowHead>2</ArrowHead>
			<ArrowHeadSize>20</ArrowHeadSize>
			<ArrowIntermSize>12</ArrowIntermSize>
			<ArrowsSnapToNodeBorders>False</ArrowsSnapToNodeBorders>
			<ArrowSegments>1</ArrowSegments>
			<ArrowText/>
			<BoxCustomDraw>0</BoxCustomDraw>
			<BoxesExpandable>False</BoxesExpandable>
			<BoxFillColor>#FFFFFF00</BoxFillColor>
			<BoxFrameColor>#FF000000</BoxFrameColor>
			<BoxIncmAnchor>0</BoxIncmAnchor>
			<BoxOutgAnchor>0</BoxOutgAnchor>
			<BoxSelStyle>1</BoxSelStyle>
			<ArrowSelStyle>1</ArrowSelStyle>
			<BoxStyle>0</BoxStyle>
			<BoxText/>
			<DynamicArrows>False</DynamicArrows>
			<IntermArrowHead>0</IntermArrowHead>
			<PenDashStyle>0</PenDashStyle>
			<PenWidth>1</PenWidth>
			<RouteArrows>False</RouteArrows>
			<ShadowOffsetX>3</ShadowOffsetX>
			<ShadowOffsetY>3</ShadowOffsetY>
			<TableCaption>Table</TableCaption>
			<TableCaptionHeight>22</TableCaptionHeight>
			<TableCellBorders>-515</TableCellBorders>
			<TableColumnsCount>2</TableColumnsCount>
			<TableColWidth>40</TableColWidth>
			<TableFillColor>#FFC0C0C0</TableFillColor>
			<TableFrameColor>#FF000000</TableFrameColor>
			<TableLinkStyle>0</TableLinkStyle>
			<TableRowHeight>22</TableRowHeight>
			<TableRowsCount>0</TableRowsCount>
			<TableSelStyle>2</TableSelStyle>
			<TablesScrollable>False</TablesScrollable>
			<TextColor>#FF000000</TextColor>
			<TextFormat Alignment="Center" LineAlignment="Center" XValue="37"/>
			<TableStyle>0</TableStyle>
			<ArrowTextStyle>0</ArrowTextStyle>
		</Defaults>
		<DefaultsGDI>
			<BoxBrush Id="0"/>
			<TableBrush Id="1"/>
			<ArrowBrush Id="2"/>
			<BoxPen>
				<Color>#FF000000</Color>
				<DashStyle>0</DashStyle>
				<Width>1</Width>
			</BoxPen>
			<TablePen>
			</TablePen>
			<ArrowPen>
			</ArrowPen>
		</DefaultsGDI>
		<Grid>
			<AlignToGrid>True</AlignToGrid>
			<GridColor>#FF8C8C96</GridColor>
			<GridSize>16</GridSize>
			<ShowGrid>False</ShowGrid>
			<GridStyle>0</GridStyle>
		</Grid>
		<Layout>
			<DocExtents Left="-5" Top="-5" Right="837" Bottom="834"/>
			<ScrollX>-5</ScrollX>
			<ScrollY>-5</ScrollY>
			<ZoomFactor>100</ZoomFactor>
		</Layout>
		<Miscellaneous>
			<MeasureUnit>2</MeasureUnit>
			<ShowDisabledHandles>True</ShowDisabledHandles>
			<FeedbackPenStyle>0</FeedbackPenStyle>
			<FeedbackPenWidth>2</FeedbackPenWidth>
			<FeedbackOnDragOver>True</FeedbackOnDragOver>
			<FeedbackColor>#FFFF8040</FeedbackColor>
			<EnableStyledText>False</EnableStyledText>
			<DragDropMode>0</DragDropMode>
			<CrossRadius>8</CrossRadius>
			<ArrowCrossings>0</ArrowCrossings>
			<AllowMultiSel>True</AllowMultiSel>
			<IconTextHeight>50</IconTextHeight>
			<IconTextWidth>100</IconTextWidth>
		</Miscellaneous>
	</Environment>
	<Boxes Count="1">
		<Box Id="0" ZIndex="0">
			<Shape>Rectangle</Shape>
			<Brush Id="3"/>
			<Pen>
				<Width>1</Width>
			</Pen>
			<Constraints Count="5">
				<Constraint Type="0">
					<Value>0</Value>
				</Constraint>
				<Constraint Type="1">
					<Value>0</Value>
				</Constraint>
				<Constraint Type="2">
					<Value>0</Value>
				</Constraint>
				<Constraint Type="3">
					<Value>0</Value>
				</Constraint>
				<Constraint Type="4">
					<Value>0</Value>
				</Constraint>
			</Constraints>
			<AnchorPattern Id="0"/>
			<BoundingRect Left="488" Top="426" Right="664" Bottom="490"/>
			<ShapeRotation>0</ShapeRotation>
			<CustomDraw>1</CustomDraw>
			<Expandable>False</Expandable>
			<Expanded>True</Expanded>
			<FillColor>#FFC0C0C0</FillColor>
			<FrameColor>#FF000000</FrameColor>
			<IncmAnchor>7</IncmAnchor>
			<Locked>False</Locked>
			<MnpHandlesMask>-1</MnpHandlesMask>
			<OutgAnchor>7</OutgAnchor>
			<BkgrImagePos>2</BkgrImagePos>
			<Selected>False</Selected>
			<SelStyle>2</SelStyle>
			<Text>aaa
aa
a
aaa</Text>
			<PolyTextLayout>False</PolyTextLayout>
			<ToolTip/>
			<Transparent>False</Transparent>
			<Visible>True</Visible>
			<Printable>True</Printable>
			<RotationAngle>0.000000</RotationAngle>
			<RotateContents>False</RotateContents>
			<RotateText>False</RotateText>
			<UserData>0</UserData>
			<UserString/>
			<NumberTag>0</NumberTag>
			<AllowInplaceEdit>True</AllowInplaceEdit>
			<Obstacle>True</Obstacle>
			<Hyperlink/>
			<IgnoreLayout>False</IgnoreLayout>
			<VariantTag>AAACAAAAAAA=</VariantTag>
			<DecorationColor/>
			<AllowIncomingArrows>True</AllowIncomingArrows>
			<AllowOutgoingArrows>True</AllowOutgoingArrows>
		</Box>
	</Boxes>
	<ControlHosts Count="0"/>
	<Tables Count="0"/>
	<Containers Count="0"/>
	<Arrows Count="0"/>
	<Groups Count="0"/>
</Diagram>
I added three CRLF sequences between three 'a's each.
However, in FlowChart X v4.8 it shows the text in one line. What am I doing wrong?
Greetings
Thomas
Reply #5 - Feb 10th, 2016 at 2:32pm
Dear Thomas,
It could depend on the TextStyle value of boxes. Try setting the default value to multi-line using FlowChart.TextStyle Property before loading the XML.
