Normal Topic Self loops (Read 2653 times)
danilom
Self loops
Jan 31st, 2016 at 9:36pm
Hi Stoyo,
I am using WPF diagramming v. 3.0.0.
When I try to connect two anchor points of the same node, the resulting link is a closed curve connecting a new anchor point above the node (see attachment).
I would like, instead, to see a standard cascading link connecting the real anchor points.
Can I obtain it?
Thanks in advance,
Danilo
Re: Self loops
Reply #1 - Feb 1st, 2016 at 10:17am
Hello there,
See if you have SetSelfLoopShape event in version 3.0 and handle it by assigning link's OriginAnchor and DestinatinoAnchor and calling Route(). If SetSelfLoopShape is missing you'll just have to handle more events, like LinkCreated and LinkModified, and also check if the link has become a self-loop from their handlers.
danilom
Re: Self loops
Reply #2 - Feb 1st, 2016 at 5:37pm
Thanks Slavcho.
SetSelfLoopShape event seems not available.
could you please provide me a small code snippet for this issue?
Checking the Linkcreated event, seems that Origin and Destination Anchors are set correctly.
The Link shape has been forced to bezier and I'm not able to convert it back successfully as cascading.
Danilo
Re: Self loops
Reply #3 - Feb 2nd, 2016 at 2:18pm
Hello Danilo,
Shape setter could reject Cascading value if the link has only one segment. Set larger SegmentCount too before assigning to Shape -
private void OnLinkCreated(object sender, LinkEventArgs e)
	var link = e.Link;
	if (link.Origin == link.Destination)
		link.SegmentCount = 3;
		link.Shape = LinkShape.Cascading;
		link.StartPoint = link.OriginConnection.
			GetAnchorPos(link.OriginAnchor);
		link.EndPoint = link.DestinationConnection.
			GetAnchorPos(link.DestinationAnchor);
		link.Route();
danilom
Re: Self loops
Reply #4 - Feb 2nd, 2016 at 2:40pm
Wonderful, thanks a lot.
As usual, your support is extremely prompt and effective.
Bye,
Danilo
