Normal Topic creat Shapes (Read 3733 times)
Jim li
creat Shapes
Jun 2nd, 2016 at 3:13am
I draw a shape with winform method,it works well
new Shape(
null,
new ElementTemplate[] {
            new LineTemplate(30, 20, 30, 80),
            new ArcTemplate(20, 30, 19, 19, 0f, 442.4054f),
            new ArcTemplate(20, 50, 19, 20, 26.56505f, 395.3776f),
            new LineTemplate(50, 10, 50, 90),
            new ArcTemplate(60, 30, 20, 20, 21.37062f, 355.1337f),
            new ArcTemplate(60, 49, 20, 20, 0f, 397.304f),
            new LineTemplate(70, 20, 70, 80)
ShapeTextArea,
FillMode.Winding, "test")
but when i use jsDiagram to draw it,
new Shape(
{ outline: 'M30,20 L30,80 A20,30,19,19,0,442.4054 A20,50,19,20,26.56505,395.3776 '+
'M50,10 L50,90 A60,30,20,20,21.37062,355.1337 A60,49,20,20,0,397.304 M70,20 L70,80', fillMode: "evenodd", decoration: '', id: 'test' });
it can not work
Lyubo
MindFusion team
Re: creat Shapes
Reply #1 - Jun 2nd, 2016 at 6:35am
You can import shape libraries defined with the ShapeDesigner tool that is bundled with the diagramming package using the ShapeLibrary class.
If you prefer defining shapes from code, you can define same shape like this:
Code (Javascript)
var shape = new MindFusion.Diagramming.Shape({outline: '',
decoration:"M30,20 L30,80 M39,40 A29.5,39.5,9.5,0,7.72143085860252,0 M37.9970584017805,64.47213577124947 C35.65066063542834,69.41192079622314,29.944266791037986,71.41416438750807,25.251471017313,68.94427200187421 C20.55867524358802,66.47437961624036,18.656543831867335,60.4676492537242,21.0029415982195,55.52786422875053 C23.349339364571662,50.588079203776864,29.05573320896201,48.585835612491934,33.748528982687,51.05572799812579 C38.44132475641198,53.525620383759644,40.34345616813266,59.5323507462758,37.9970584017805,64.47213577124947 M50,10 L50,90 M79,44 A70,40,10,0.3729876821925506,6.571240031982336,0 M80,59 A70,59,10,0,6.93426293134355,0 M70,20 L70,80",
fillMode: 'nonzero', id: 'test'})
Note that JsDiagram uses the outline bounds when hit-testing and this shape doesn't provide one.
If you'll need interaction you can set the shape path as an outline element in the code above and leave the decoration portion empty. If you need to remove the fill, you can set the node's brush to transparent.
Lyubo
Jim li
Re: creat Shapes
Reply #2 - Jun 2nd, 2016 at 7:02am
CoolThanks ,it worked.
Can you give me a Download link about the ShapeDesigner tool?
I have one but can only export shape code for C#  and VB.NET,not for javascript.
Lyubo
MindFusion team
Re: creat Shapes
Reply #3 - Jun 2nd, 2016 at 8:13am
It's the same tool. Use File -> Save Library (or press Ctrl+S) to save the library as a XML file. Use the "xml" extension instead of the default "shl", or you may need to modify your application/server MIME type settings.
Lyubo
Jim li
Re: creat Shapes
Reply #4 - Jun 3rd, 2016 at 8:32am
I'm sorry to trouble you again,i have two more questions:
1: I use this code to create a shape
new Shape(
fillMode: "nonzero",
outline: 'M30,20 L30,80 M40,40.5 A30,40,10,0,6.283185,0 M40,60 A30,60,10,0,6.283185,0 ' +
'M50,10 L50,90 M80,40 A70,40,10,0,6.283185,0 M80,60 A70,60,10,0,6.283185,0 M70,20 L70,80',
decoration:'',
shapeDecoration: "",
outlineBrush: "transparent",
outlinePen: "transparent",
decorationPen: "transparent",
decorationBrush: "transparent",
shapeDecorationPen: "",
shapeDecorationBrush: ""
and i also to user method : setBrush("transparent");
but i still can't to remove the fill
2:Is there a method to set diagram.nodes[i].shapeRenderer propertys?
Lyubo
MindFusion team
Re: creat Shapes
Reply #5 - Jun 3rd, 2016 at 9:26am
1. The above code successfully removes the fill of the shape for me, but what remains is the drop shadow fill. You can either set the shadow brush to transparent like this:
Code (Javascript)
node.setShadowColor('transparent');
or disable shadows globally through
Code (Javascript)
diagram.setShadowsStyle(MindFusion.Diagramming.ShadowsStyle.None);
2. The shapeRenderer object is meant to be used internally and doesn't provide a public interface. Any property values that you set may get overwritten in a subsequent repaint.
Lyubo
