Normal Topic Add Chart3D and Pie3D behavior RotateModel (Read 4168 times)
abrechts
Jun 7th, 2016 at 11:04am
Currently the perspective of the 3D models only can be changed by rotating the *camera* around the model by applying Behavior3D.ChangePerspective. This has the disadvantage that when examining the model in space one will invariably end up in dark and shadowy areas of it, since the light sources don't rotate along, which is less than ideal.
The more optimal behavior would be to rotate the *model* instead, which always keeps the light sources at the same angle to camera and model, and thus provides consistent illumination. Therefore the implementation of an additional behavior enumeration e.g. called Behavior3D.RotateModel could vastly improve the user experience.
Re: Add Chart3D and Pie3D behavior RotateModel
Reply #1 - Jun 7th, 2016 at 11:24am
Lights follow the camera by default so you should see model's shiny side projected, and that's what I'm seeing in the sample projects. Maybe check if you haven't added a Light instance to the Chart3D.StaticLights collection - those do not follow the camera but stay fixed in the scene.
abrechts
Reply #2 - Jun 7th, 2016 at 12:15pm
You are right - I actually did have some static lights applied. I added them because the Chart3D model gets over-proportionally dark when viewing a surface from less than a 45°C angle, but still fully in light direction. Is there a way to ease this effect a bit, towards a less high-contrast image result?
Reply #3 - Jun 7th, 2016 at 2:02pm
Try adding more lights to soften shadows, either a DirectionalLight pointing down or a PointLight, e.g. we add a second light in SurfaceChart example exactly for that purpose -
DirectionalLight light = new DirectionalLight()
    Color = Colors.White,
    Direction = new Vector3D(-1, 3, -1),
surfaceChart.StaticLights.Add(light);
You could add it to Lights collection instead to make it keep its relative position to camera.
abrechts
Reply #4 - Jun 8th, 2016 at 12:34pm
I've found that the addition of an AmbientLight does the trick to ease the contrasts. Following light combination currently works pretty well for my stacked 3D chart with cylinders, maybe it also helps someone else (vb.net):
with myChart3D
.Lights.Clear()
.StaticLights.Clear()
.StaticLights.Add(New AmbientLight(Color.FromRgb(110, 110, 110)))
Dim light = New DirectionalLight()
With light
.Color = Color.FromRgb(155, 155, 155)
.Direction = New Vector3D(-1, -1, -2)
End With
end with
