Normal Topic JDiagram 4.2 SVG Exporter (Read 4500 times)
Jasef
Jul 19th, 2016 at 1:56am
we've noticed that the SVG Exporter handles outputting images incorrectly.
The image seems to be placed in the right spot, but not within it's associated component.
It feels like the image is missing the positional matrix transformation from it's associated component.
We're currently running JDiagram 4.1.4, but I've tested this 4.2 as well.
I've provided a screenshot of what it's suppose to be look like, how it looks on Chrome 51.0.2704.103, a test case (Against 4.2) and an SVG output.
Cheers,
Jasef.
Re: JDiagram 4.2 SVG Exporter
Reply #1 - Jul 20th, 2016 at 11:35am
This v4.2 build should fix the image position in SVG -
https://mindfusion.eu/_temp/JDiagram.zip
Jasef
Reply #2 - Jul 20th, 2016 at 7:59pm
That build works perfectly.
Is there an expected time frame for an official release version?
(Not a priority fix for us)
Cheers,
Jasef.
Reply #3 - Jul 21st, 2016 at 9:04am
This build is from a stable branch of the code, so should be safe to use. We'll be releasing updated version in September.
