Normal Topic External labels for nodes (Read 2052 times)
Sabrina C.
Sep 12th, 2016 at 2:01pm
we're trying to find good way to put labels of nodes external with respect to the bounding box of the node (e.g. on the bottom). We need such functionality because often the node itself is a way too small to encapsulate all the text we need to layout. At the same time, we want that any arrows connected to the node bounding box behaves the same without interfering with the text. The text box should be bigger than the bounding box of the node to include more lines of text.
Currently we're struggling with different type of elements in the node template hierarchy, but none of them works as intended.
Do you have any suggestion?
Re: External labels for nodes
Reply #1 - Sep 13th, 2016 at 9:08am
Here's one way to do it -
<DataTemplate DataType="{x:Type local:MyNode}">
	<Canvas ClipToBounds="False">
		<Ellipse Stroke="Red" Width="{Binding Bounds.Width}" Height="{Binding Bounds.Height}" />
		<TextBlock Canvas.Top="{Binding Bounds.Height}" Text="{Binding Text}" />
	</Canvas>
</DataTemplate>
It can probably be done with grid or stack panels too, e.g. by binding first row's height to node's height.
Sabrina C.
Reply #2 - Sep 19th, 2016 at 9:02am
Thank for your reply. We're already tried with Canvas, and we're sticking to it since it is the only solution that allows the textblocks to overflow node bounds.
S.
Reply #3 - Sep 19th, 2016 at 11:38am
I've managed to allow overflow with Grid panel too, by means of negative margin -
	<Grid ClipToBounds="False" Margin="0,0,0,-100">
		<Grid.RowDefinitions>
			<RowDefinition Height="{Binding Bounds.Height}" />
			<RowDefinition Height="Auto" />
		</Grid.RowDefinitions>
		<Ellipse Stroke="Red" />
		<TextBlock Grid.Row="1" Text="{Binding Text}" />
	</Grid>
</DataTemplate>
The margin specified like that serves as a MaxHeight for the auto-sized row, kind of. Otherwise Auto takes lower precedence than available height set by the node, and the text row would be measured as zero-height.
