Normal Topic Registering custom items and custom behaviour (Read 2781 times)
Gravity
Sep 21st, 2016 at 11:46am
I am trying out these diagrams. I have kind of a problem finding info on Diagram.RegisterItemClass
how do you register custom shapeNode?
For example i saw with Scheduler you have methods for handling item class registration it has IsClassRegistered, RegisterItemClass and UnregisterClass. Which i am missing in web forms.
Re: Registering custom items and custom behaviour
Reply #1 - Sep 21st, 2016 at 12:01pm
If you need to create custom types for default Canvas mode, you must create classes in both .NET and JavaScript, and also a JavaScriptConverter to transfer them in JSON format between client and server. You tie them all together using DiagramView's RegisterItemType and RegisterConverters methods, as shown in IconNodes sample project for the CustomNode class.
Diagram.RegisterItemClass is used mostly in the desktop version of the control which shares an assembly with ASP.NET one, and it's called internally by DiagramView's method.
Gravity
Reply #2 - Sep 21st, 2016 at 12:27pm
Thank you very much. During that time I've read documentation, that's the answer thanks : )
