Normal Topic How to subscribe to node clicked event? (Read 3039 times)
Gravity
Oct 5th, 2016 at 10:49am
I find it difficult to subscribe to node click event. I tried js (as shown in sample) and server side, but those event seems to never happening. So there is probably a problem the way i describe them, it seems that i need to do something extra, maybe enabling some property?. I'am interested in client/server side.
Could someone help with that?
Gravity
Re: How to subscribe to node clicked event?
Reply #1 - Oct 5th, 2016 at 1:30pm
Gravity wrote on Oct 5th, 2016 at 10:49am:
Ok, found it
On client script you need to set property of diagramming control like so:
   NodeClickedScript="onNodeClicked"
   <script type="text/javascript">
         function onNodeClicked(sender, args) {
            if (sender == null)
                return false;
            var node = args.getNode();
            console.log("node", node);
            return true;
    </script>
Reply #2 - Oct 5th, 2016 at 2:28pm
Right. You could also handle some events on server but clicked is not among them. If you enable AutoPostBack, the control will post back after create, modify, delete and text-edit operations and raise respective DiagramView events.
