Normal Topic Possible Primitives for polygon creation? (Read 2287 times)
Kim Lillås
Nov 29th, 2016 at 2:45pm
I was looking at the Diagramming Sample Shape Designer example for WPF. In that example there are 4 "Primitives" (Line, squiggly line, ...).
Does there exist a library of Primitives in Mindfusion, or are these Primitives custom defined Shapes especially made for the demo?
//Kim
Re: Possible Primitives for polygon creation?
Reply #1 - Nov 30th, 2016 at 6:39am
These are standard ElementTempalte-derived classes you would use to create custom Shape objects from code - LineTemplate, BezierTemplate, ArcTemplate, RoundRectangleTemplate. You add them to Shape's outline and decoration arrays to define ShapeNode geometry. We could make some members of ElementTemplate public to let you override them if you'd like to create your own primitives.
Kim Lillås
Reply #2 - Nov 30th, 2016 at 12:24pm
Thanks for the information, time to look closer at the code then =)
But yes, it would be good to be able to create user defined templates.
Cheers,
Kim
