It's an InplaceEditEventArgs object with getItem() and getControl() members. You'd use this mostly for cleanup if you've created a custom editor UI from enterInplaceEditMode handler.
If using standard text box, you could handle nodeTextEdited and linkTextEdited events, their event arguments have more specific getNode() and getLink() functions.
Add this to your script file to get code completion in Visual Studio -
/// <reference path="MindFusion.Diagramming-vsdoc.js" />
It will work only for variables that VS can directly link to MindFusion types defined in the vsdoc.js file. E.g. you will get completion working for diagram variable if it's created through Diagram static method, but not through global functions like $find or $create (from MS Ajax) -
var diagram = Diagram.create($get("diagram"));
Once VS knows diagram variable refers to MindFusion.Diagramming.Diagram, it will infer types of other objects accessed through it -
Completion won't work in event handlers unless you add your own type annotations for the handler functions, either through <param name="..." type="..." comments as in our vsdoc file or using VS script context API -
https://msdn.microsoft.com/en-us/library/hh874692.aspxRegards,
