Very Hot Topic (More than 25 Replies) mark link branch (Read 20866 times)
Re: mark link branch
Reply #15 - May 18th, 2017 at 4:21pm
Try LinkMergeIndicator, MergeIndicatorColor, MergeIndicatorSize properties here -
https://mindfusion.eu/_temp/fcnet_merge.zip
NiceGuy
Reply #16 - Jun 21st, 2017 at 1:52pm
Hi, thanks for your beta. But here are unfortunately a few inconsistencies.
Best regards.
Reply #17 - Jun 22nd, 2017 at 8:32am
Does it show an adjustment handle there is you select the links?
NiceGuy
Reply #18 - Jun 23rd, 2017 at 5:50am
Hello, the black dots are the ones we would expect.
Reply #19 - Jun 28th, 2017 at 11:48am
This build should fix it -
NiceGuy
Reply #20 - Jul 6th, 2017 at 12:32pm
Hi, yes the points are right, very good work. However, I can not affect the size of the points correctly. Can it be that the size internally is still influenced?
Reply #21 - Jul 6th, 2017 at 1:45pm
There's a separate MergeIndicatorSize property for merger points, have you set it?
NiceGuy
Reply #22 - Jul 6th, 2017 at 2:08pm
Yes I have made, but starting from a certain size, this is no longer used, I need the points smaller. If I enter 10 or 0.5 the point always has the same size.
Reply #23 - Jul 6th, 2017 at 2:13pm
So it was using merge size for branch points and the other way around. This should fix it -
diagram.MergeIndicatorSize = 20;
diagram.MergeIndicatorColor = Color.Red;
diagram.BranchIndicatorSize = 15;
diagram.BranchIndicatorColor = Color.Green;
NiceGuy
Reply #24 - Jul 6th, 2017 at 3:18pm
Wonderful, it works. Many Thanks  Smiley
NiceGuy
Reply #25 - Aug 22nd, 2017 at 6:00pm
Hello, I have another question.
Can you provide me a way to attach to the drawing routine? It would be best to get coordinates for each circle (branch and merge indicator).
I need a way to make the circle look different, unfortunately it is not enough to influence only the size and color.
Best regards
Reply #26 - Aug 24th, 2017 at 8:36am
This adds Custom element to BranchIndicator enumeration -
https://mindfusion.eu/_beta/fcnet65.zip
Assign it to LinkMergeIndicator and / or LinkBranchIndicator and the diagram will raise DrawBranchIndicator event -
void OnDrawBranchIndicator(object sender, DrawBranchIndicatorEventArgs e)
	e.Graphics.DrawRectangle(
		e.Merge ? Pens.Red : Pens.Green,
		e.Position.X - 1, e.Position.Y - 1, 2, 2);
NiceGuy
Reply #27 - Aug 26th, 2017 at 4:05pm
Thank you very much for the fantastic work, you saved my day.  Smiley
Best regards
