Normal Topic TimeTableView - select visible date (Read 5402 times)
john6630
Mar 2nd, 2017 at 4:37pm
Hi Meppy,
Sorry for so many questions. I need to set the calendar dates to a wider range of dates but then select one of the dates to be the first visible. The user can then scroll horizontally between the other dates. I can not see how to do that.
Thank you,
John
Re: TimeTableView - select visible date
Reply #1 - Mar 3rd, 2017 at 10:38am
You can assign the date index within TimetableSettings.Dates to calendar's ScrollPosition.X -
// starts from the 5th date zero based
calendar.ScrollPosition = new Point(4, 0);
john6630
Reply #2 - Mar 3rd, 2017 at 4:49pm
I am having trouble getting the date index in Timetable Dates. I am using the following
calendar.TimetableSettings.Dates.IndexOf(Cdate("11/22/2017")) and it returns -1 but that date is on my calendar.
What am I doing wrong?
Thank you,
John
Reply #3 - Mar 3rd, 2017 at 5:07pm
The Dates element might be unequal to the value you compare with if it has non-zero Time properties set. Try looping over the collection and comparing only the DateTime.Date values to find the index.
john6630
Reply #4 - Mar 3rd, 2017 at 5:23pm
My mistake. Using indexOf works fine. I had the wrong year in my test date.
Thank you,
John
