Normal Topic Customizing the ContainerNode title bar (Read 2850 times)
j poz
Mar 28th, 2017 at 5:14pm
Is it possible to add custom controls to the title bar of the ContainerNode?
Re: Customizing the ContainerNode title bar
Reply #1 - Mar 29th, 2017 at 6:17am
If you use a derived class, you could follow same approach ContainerNode uses to show its fold icon -
class TestWidget : MindFusion.Diagramming.Manipulators.Manipulator
	public TestWidget(DiagramItem item, RectangleF bounds)
		: base(item)
		this.bounds = bounds;
	public override bool HitTest(PointF point)
		return bounds.Contains(point);
	public override void Draw(IGraphics graphics)
		graphics.DrawRectangle(Pens.Blue, bounds);
	public override void OnClick(PointF point)
		MessageBox.Show("click");
	public override bool SupportClipping()
		return false;
	public override void AddToRepaintRect(ref RectangleF rect)
	RectangleF bounds;
class TestNode: ContainerNode
	public TestNode(Diagram diagram)
		: base(diagram)
		AddManipulator(
			new TestWidget(this, new RectangleF(2, 2, 4, 4)));
Otherwise you could use AttachTo method to attach some helper ControlNode or ShapeNode objects to the container, and handle their click events to modify it.
j poz
Reply #2 - Jul 14th, 2017 at 4:21pm
This worked well, thank you.
Do you know how we would add a tooltip when the mouse rests over a small area of the container title, and not the entire container?
Reply #3 - Jul 14th, 2017 at 5:14pm
Try returning it from DiagramNode.GetToolTip(point) override if point is inside the area, or return base result otherwise.
