Normal Topic Disable default drawing new node behavior on diagram (Read 1542 times)
Alex_Z
May 4th, 2017 at 5:47pm
When we try to hold and move cursor, it will automatically draw new node. Since we have NodeListView and we're expecting end-user selecting node from NodeListView instead of drawing directly on diagram, is there any way to disable this default behavior?
Thanks in advance!
Online
Re: Disable default drawing new node behavior on diagram
Reply #1 - May 4th, 2017 at 6:34pm
Hi!
Yes, set diagram's Behavior property to either DrawLinks, Modify, SelectOnly depending on what you allow users to do -
var Behavior = MindFusion.Diagramming.Behavior;
diagram.setBehavior(Behavior....);
http://www.mindfusion.eu/onlinehelp/jsdiagram/index.htm?CC_T_MindFusion_Diagramm...
