Normal Topic MindFusion XML Viewer 4.1: Problem with memory (Read 9652 times)
Mirsait
Jun 21st, 2017 at 12:30pm
After opening in turn 3 -4 large files (~ 250 MB each) memory is not freed.
Actions: (open the file -> close the file ) * 3
System: W8.1 x64
Program: MindFusion XML Viewer 4.1
Re: MindFusion XML Viewer 4.1: Problem with memory
Reply #1 - Jun 27th, 2017 at 7:25am
The application is built using .NET and relies on a Garbage Collector to free unused memory. Occasionally the used memory should be freed. Do you run out of memory if you continue to open and close large files?
Reply #2 - Jul 19th, 2017 at 12:59pm
New version here should fix the leak -
https://mindfusion.eu/XMLViewer.zip
