Normal Topic Draw arrow after resizing or moving shape node (Read 1828 times)
friedel
Jun 23rd, 2017 at 10:35am
Hi. I have found a problem, that after moving or resizing shapeNode I wasn't able to draw arrow from right/left corner. Instead of drawing arrow shapeNode is just resizing or moving. Without moving/resizing it works fine.
After moving/resizing
I have checked, that no event was fired on arrow link dragging from shapeNode
Re: Draw arrow after resizing or moving shape node
Reply #1 - Jun 26th, 2017 at 10:33am
Difference might be coming from selection state of nodes. Selected nodes give higher precedence to adjustment handle hit-testing and associated move/resize operations, even if you use Invisible or Custom handle types. Try clearing selection by calling node.setSelected(false) from nodeModified event handler to see if it helps. Nodes get selected automatically when you start resizing if the ModificationStart property is set to AutoHandles;
