Hot Topic (More than 10 Replies) Shape connectivity restriction for specific shapes (Read 7059 times)
ashar11
Jun 30th, 2017 at 11:17am
          I am working on winforms and using a flowcharter from the samples in c#, I want to restrict specific shape connectivity like in the image url given below i want to restrict the connectivity of shape A and shape C how can i do that.
https://imagebin.ca/v/3RkcP2F80Wof
The code from which i am getting images right now is :
   // nodeListView1
            this.nodeListView1.Location = new System.Drawing.Point(-3, 210);
            this.nodeListView1.Name = "nodeListView1";
            this.nodeListView1.Size = new System.Drawing.Size(200, 343);
            this.nodeListView1.TabIndex = 0;
            this.nodeListView1.AddNode(new ShapeNode
                Transparent = true,
                Image = Image.FromFile(@"C:/Imgs/bitmap1.bmp")
            }, "A");
                Transparent = true,
                Image = Image.FromFile(@"C:/Imgs/bitmap2.bmp")
            }, "B");
                Transparent = true,
                Image = Image.FromFile(@"C:/Imgs/bitmap3.bmp")
            }, "C");
Online
Re: Shape connectivity restriction for specific shapes
Reply #1 - Jun 30th, 2017 at 12:23pm
If you mean some nodes should not accepts links, set their AllowIncomingLinks and / or AllowOutgoingLinks properties.
ashar11
Reply #2 - Jun 30th, 2017 at 12:50pm
thanks slavcho ,it is similar to what i need but actually what i want is, like shape C can be connected to shape A but not with shape B,so how can i apply condition with in the given code i post before.
Online
Reply #3 - Jun 30th, 2017 at 1:19pm
You will need to handle the LinkCreating validation event and set e.Cancel to true if the pair of nodes is not allowed by your criteria. For example this will not let users draw if source node is on the right side of destination node.
void diagram_LinkCreating(object sender, LinkValidationEventArgs e)
	if (e.Origin != null && e.Destination != null)
		if (e.Origin.Bounds.X > e.Destination.Bounds.X)
			e.Cancel = true;
ashar11
Reply #4 - Jul 3rd, 2017 at 8:52am
With this code below which is in Mainform.Designer.cs where to apply the changes ?i even can't initialize the function its giving me errors
   // nodeListView1
                Transparent = true,
            }, "A");
                Transparent = true,
            }, "B");
                Transparent = true,
            }, "C");
I am not that expert so can you define it more please,I dont have the indexing of nodes here, just the label A,B,C so how to differentiate between nodes if i want to apply condition for restricting connection among nodes.Thanks
Online
Reply #5 - Jul 3rd, 2017 at 9:47am
Select the Diagram instance in form designer and in property window's events tab double click on LinkCreating event to add the event handler. Alternatively add event handler from code -
diagram.LinkCreating += diagram_LinkCreating;
You might want to set the nodes' Id or Tag property to your "A", "B" etc values and do checks based on them in the validation code -
if ("A".Equals(e.Origin.Tag) && "B".Equals(e.Destination.Tag))
If you have a lot of pairs you'll need to check, consider creating a matrix of Boolean values to hold information what pairings are allowed; then LinkCreating could return information from the matrix directly.
ashar11
Reply #6 - Jul 3rd, 2017 at 10:24am
Thanks slavcho for detailed description. This is now what i am using but still i am able to connect both nodes...how to stop them from connecting
private void diagram_LinkCreating(object sender, LinkValidationEventArgs e)
e.Cancel = true;
Online
Reply #7 - Jul 3rd, 2017 at 10:31am
Have you set the nodes' Tag property when populating your NodeListView?
ashar11
Reply #8 - Jul 3rd, 2017 at 10:35am
This is how i am getting the images ,you talking about these tags(A,B,C)?
   // nodeListView1
                Transparent = true,
            }, "A");
                Transparent = true,
            }, "B");
                Transparent = true,
            }, "C");
ashar11
Reply #9 - Jul 3rd, 2017 at 11:21am
Thanks Slavcho you are great, Issue is resolved now Smiley
ashar11
Reply #10 - Jul 3rd, 2017 at 12:48pm
Slavcho one thing more if you can tell me, how to limit links for a specific node within this code, like i want Node A to create only 2 links and accept only 1 link. Thanks
  if ("A".Equals(e.Origin.Tag) )
                e.Cancel = true;
ashar11
Reply #11 - Jul 3rd, 2017 at 12:49pm
This will be second condition for node A
            //diagram.LinkCreating += diagram_LinkCreating;
                e.Cancel = true;
            if ("A".Equals(e.Origin.Tag))
                e.Cancel = true;
Online
Reply #12 - Jul 3rd, 2017 at 1:09pm
Check the Count property of nodes' OutgoingLinks and IncomingLinks collections. Keeping in mind that the currently drawn link is not yet there.
ashar11
Reply #13 - Jul 4th, 2017 at 5:02am
Its fixed now thanks Slavcho.
