Normal Topic Custom link serialization (Read 2531 times)
Francesco
Jul 3rd, 2017 at 3:35pm
I have a CustomDiagramLink, subclass of DiagramLink, I can save it through SaveToXml, but when I load I get a InvalidOperationException exception.
Here is written (Point 5) that I should call RegisterItemClass on the diagram
http://www.mindfusion.eu/onlinehelp/flowchartnet/Serialization_of_FlowChart_NET_...
But the Diagram class does not look to have RegisterItemClass
Here is written that a parameter-less constructor (or one with a diagram parameter) should be provided by the custom class.
http://www.mindfusion.eu/onlinehelp/flowchartnet/M_MindFusion_Diagramming_Diagra...
So, I have built a constructor with only a diagram parameter, and things seem to work. But is it correct?
Also, while the saved diagram could display proper arrowheads, the diagram loaded from a file does not show the arrowheads, even if I add this feature after loading the diagram from file!
(I do:
Diagram.LinkBaseShape = MindFusion.Diagramming.Wpf.ArrowHeads.Arrow;
and - even if it should not be necessary - in each link:
this.HeadShape = MindFusion.Diagramming.Wpf.ArrowHeads.Arrow;
What could I do?
I have none of these problems with Node's subclasses.
Francesco
Re: Custom link serialization
Reply #1 - Jul 3rd, 2017 at 3:38pm
Sorry, I just came across this. So, I'll check it and let you know:
http://mindfusion.eu/Forum/YaBB.pl?num=1498704395
Francesco
Reply #2 - Jul 3rd, 2017 at 4:01pm
Yes, this example solved my problems
(even if I still had to create a CustomLink constructor with only the diagram as parameter - but this looks reasonable)
Reply #3 - Jul 3rd, 2017 at 5:10pm
I think you will miss the arrowheads if you register the custom class with serialization format ID = 1 (last argument to RegisterItemClass). The base DiagramLink tries to parse arrowheads as integer values in format 1, later they were replaced by string identifiers. Problem is the same format ID is used for both yours and base class, so you should pass value larger than ours when registering (that's why the 100 in sample code you've linked). We plan to store separate identifiers for item classes from the hierarchy in upcoming revision of serialization schema to fix that.
Both no-args and (Diagram) constructors should work otherwise.
Francesco
Reply #4 - Jul 3rd, 2017 at 6:31pm
Thank you!
