Normal Topic I Cut group node,but I can't paste it! (Read 3257 times)
chowy
Jul 10th, 2017 at 4:46am
I Cut group node,but I can't paste it! After I paste it, it becomes an empty groupnode! In my GroupNode's DiagramItem Clone(bool clipboard) method,I create a new groupNode,but the new groupNode.SubordinateGroup is null.How can I assign the cut groupnode.SubordinateGroup to my new groupNode?
Re: I Cut group node,but I can't paste it!
Reply #1 - Jul 10th, 2017 at 5:57am
Calling CutToClipboard (bool copy, bool groups) overload with true as second argument?
chowy
Reply #2 - Jul 10th, 2017 at 6:47am
Slavcho wrote on Jul 10th, 2017 at 5:57am:
Yes!When I click the cut button, call diagram.CutToClipboard (true, true);
Reply #3 - Jul 10th, 2017 at 6:55am
If using custom node types, have you implemented copy constructors and serialization methods for all of them?
chowy
Reply #4 - Jul 10th, 2017 at 8:22am
Slavcho wrote on Jul 10th, 2017 at 6:55am:
Just overloading Clone, SaveToXml, LoadFromXml method?
Reply #5 - Jul 10th, 2017 at 9:58am
Clone override should work too, and don't forget to call RegisterItemClass so the control knows what types to instantiate when reading from XML. The custom nodes should have either no-arguments or (Diagram) constructor, or otherwise the load method wouldn't be able to instantiate them.
chowy
Reply #6 - Jul 10th, 2017 at 10:33am
Slavcho wrote on Jul 10th, 2017 at 9:58am:
Thank you for your reply! But how do I disable the diagram's ctrl + x and ctrl + c shortcuts?
Reply #7 - Jul 10th, 2017 at 11:57am
See http://mindfusion.eu/Forum/YaBB.pl?num=1341317161/3#3 for how to replace the command binding. So we've added the overload to cut with groups mentioned in that thread at some point, but the standard command binding still calls it without groups.
