Normal Topic How do i save a single custom node? (Read 1535 times)
chowy
Jul 17th, 2017 at 1:50am
Now I need to store a custom node on my diagram into the database, so I want to serialize the node to save it. However, I did not find a suitable way to save a single custom node. Do you have any good suggestions? I also need to export a single node to jpeg, bmp, dxf and so on.
« Last Edit: Jul 17th, 2017 at 9:29am by chowy »
Re: How do i save a single custom node?
Reply #1 - Jul 17th, 2017 at 11:28am
You could clone it into a temporary diagram and save / export the latter -
var tempDiag = new Diagram();
tempDiag.Nodes.Add(node.Clone(false));
var doc = new XmlDocument();
tempDiag.SaveToXml(doc);
var xml = doc.SelectSingleNode("Diagram/Nodes").InnerXml;
Debug.WriteLine(xml);
new PdfExporter().Export(tempDiag, "...");
