Normal Topic Scheduler and ToolStripMenu (Read 4289 times)
fractal07
Jul 26th, 2017 at 10:43am
Hi Meppy,
I'm working on a C# WinForms Scheduler and I'm stuck when I try to get the date where the user clicked, using a ToolStripMenu.
As you can see in the picture, at first the customer right-click on the scheduler (these are the coordinates I'm trying to get) and the he select an ToolStripMenuItem.
My goal is to get the date and resource of the first click...
I tried to get the client or screen position but it doesn't work :
private void _ctxMenu_OnClick(object sender, EventArgs e)
    ToolStripMenuItem item = sender as ToolStripMenuItem;
    Point client = calendar.PointToScreen(Cursor.Position);
    _pointedResource = calendar.GetResourceAt(client);
    _pointedDate = calendar.GetDateAt(client);
Please, could you give me a tip to go further?
Re: Scheduler and ToolStripMenu
Reply #1 - Jul 27th, 2017 at 7:37am
Get the coordinates of the mouse when the context menu is displayed, not when the user clicks on a menu item. For example, use the context menu's Opening event.
fractal07
Reply #2 - Jul 27th, 2017 at 9:59am
Thank you so much, it was the event I was looking for !
