Normal Topic The Diagram's grid painting position is wrong. (Read 2274 times)
chowy
Aug 11th, 2017 at 2:04am
When I initialize, set Diagram.Zoomfactor to 632, grid will be biased.I have already called Diagram.InvalidateBackground (),but it does not work.I have uploaded the demo source.
WpfApplication9.zip (Attachment deleted)
Re: The Diagram's grid painting position is wrong.
Reply #1 - Aug 11th, 2017 at 6:54pm
InvalidateBackground won't work before the diagram's template is applied. Set zoom factor from the Window.Loaded event handler and it will align the zoomed grid correctly -
public MainWindow()
    InitializeComponent();
    Loaded += (s, e) => { Diagram.ZoomFactor = 632; };
private void Diagram_OnZoomFactorChanged(object sender, EventArgs e)
    Diagram.InvalidateBackground();
private void Diagram_OnMouseLeftButtonDown(object sender, MouseButtonEventArgs e)
    Diagram.ZoomFactor = Math.Min(1000, Diagram.ZoomFactor + 10);
chowy
Reply #2 - Aug 15th, 2017 at 1:41am
Slavcho wrote on Aug 11th, 2017 at 6:54pm:
public MainWindow()
