Normal Topic DiagramView Right to Left (Read 4211 times)
Kyle Chen
Aug 15th, 2017 at 2:59pm
I'm trying to add Arabic language support to my application and found DiagramView doesn't support RightToLeft well - the VSscrollbar always shows on the right even I set RightToLeft (The vertical ruler should be on the right instead).
Can you take a look or is there any workaround?
Kyle
Re: DiagramView Right to Left
Reply #1 - Aug 16th, 2017 at 8:40am
This build now moves the vertical scrollbar to the left when you enable RightToLeft -
https://mindfusion.eu/_beta/fcnet65.zip
Kyle Chen
Reply #2 - Sep 29th, 2017 at 4:12pm
I've tested this in version 6.51 beta - it works but with a small problem. The horizontal scrollbar is not positioned well when Right to Left is set to True. Please see attached. Can you fix that? Grin
Kyle
Reply #3 - Oct 2nd, 2017 at 1:04pm
Try this build -
https://mindfusion.eu/_beta/fcnet651.zip
The Ruler control will now move its vertical scale to opposite side as well.
Kyle Chen
Reply #4 - Oct 2nd, 2017 at 8:19pm
Hi Slavcho,
Thanks for the change - it works now. But if you have chance, can you make some extra change? See below sometimes, the horizontal scroll bar not positioned perfectly - when the screen resized a little bit, it might refresh and back to normal.
Thank you!
Kyle
Reply #5 - Oct 6th, 2017 at 12:40pm
Hi Kyle,
We could not reproduce that. Please attach a test project with same form layout as yours, in case it's related to what panels are used on the form or to layout property values (dock, anchor...).
Kyle Chen
Reply #6 - Oct 6th, 2017 at 1:53pm
Hi Slavcho,
Forget it, that's not a big deal. Do you have a schedule when to release 6.51?
Kyle
Reply #7 - Oct 9th, 2017 at 7:34am
Hi Kyle,
We should release it next week.
Kyle Chen
Reply #8 - Oct 10th, 2017 at 8:11pm
Cool. Thanks!
