Normal Topic Diagramming for Windows Forms, V6.5 (Read 7461 times)
Sep 5th, 2017 at 8:11am
We have released version 6.5 of FlowChart.NET. It contains several customer-requested features and improvements:
Non-blocking layout methods
All graph layout classes now contain an async ArrangeAsync method that runs layout calculations in a background task. This is only available in .NET 4.5 build of the diagram assemblies.
async void OnLayoutLayered(object sender, EventArgs e)
    var layout = new LayeredLayout();
    await layout.ArrangeAsync(diagram);
    diagramView.ZoomToFit();
  • ImagePadding property of ShapeNode, TableNode and Cell lets you set padding space between element's borders and the contained Image.
  • LinkPadding property added to LayeredLayout specifies how much space to leave between links when LinkType is set to Cascading.
  • ContainerNodes now apply the TextPadding value.
  • Merge indicators for cascading links now supported as counter-parts of branch indicators from the 6.4.3 release. Set the LinkMergeIndicator property to specify the indicator shapes and MergeIndicatorColor and MergeIndicatorSize properties to customize their appearance.
  • Custom element added to BranchIndicator enumeration. If it's assigned to LinkBranchIndicator or LinkMergeIndicator, the control raises DrawBranchIndicator event to let you draw custom indicator graphics.
  • Export overloads that write to Stream objects added to PdfExporter, VisioExporter and Visio2013Exporter.
  • PageAdding validation event added too TabbedDiagramView control.
  • Public Item property of TreeViewConnectionPoint provides access to target TreeViewItem of links.
  • Vertical scrollbar is displayed on the left side of DiagramView when RightToLeft is enabled.
Updated assemblies are also available as MindFusion.Diagramming NuGet package.
