Normal Topic Automated layout forgetting link anchor IDs (Read 1758 times)
Kim Lillås
Oct 5th, 2017 at 4:29pm
I am trying out some automated layout for the first time.
I have a set of nodes and links.
I want them to layout without changing the existing anchor selections.
However, after the layout is done, the Link.DestinationAnchor and OriginAnchor is set to -1, and visually the links no longer tie to the original anchor points.
The assignment of -1 happens during the automated layout operation. I assumed that the layout.Anchoring = Anchroing.Keep setting would force the layout to keep the link anchors?
         var layout = new MindFusion.Diagramming.Wpf.Layout.DecisionLayout();
         layout.Anchoring = Anchoring.Keep;
         layout.GrowToFit = true;
         var diagramItemCollection = new DiagramItemCollection();
         foreach (var diagramItem in MindfusionDiagram.Items.Where(x => x.GetType() != typeof(NestedDiagram)))
            diagramItemCollection.Add(diagramItem);
         layout.Arrange(MindfusionDiagram, diagramItemCollection);
Re: Automated layout forgetting link anchor IDs
Reply #1 - Oct 6th, 2017 at 3:53pm
This build should keep them -
https://mindfusion.eu/_beta/wpfdiag_anckeep.zip
Node positions are not affected by anchor points though, the layout class aligns links to points only as a post-processing step at this time. So this could lead to links taking several U-turns to get from outgoing to incoming anchor points.
Kim Lillås
Reply #2 - Oct 9th, 2017 at 6:27am
Thanks for the answer!
Greetings,
Kim
