Hot Topic (More than 10 Replies) Issue with routing of link to a rotated node with high width to height ratio. (Read 10363 times)
beetee
Oct 27th, 2017 at 8:28am
Hello
Refer the attached image. There are two types of nodes used.
One is a black bar and it has one anchor point at the center. Second one is with two circles with one anchor point.
Bar on the right side is rotated 90 degrees and in this case when a link is drawn (number 3) to a point below the center of the bar it takes a long route. I'm expecting a link routed along the red line as it has drawn in the link number 2.
This is observed only when the bar is rotated 90 or 270 degrees and the destination point of the link is below the center of the bar.
What could be the reason?
Thank you
beetee
Re: Issue with routing of link to a rotated node with high width to height ratio.
Reply #1 - Oct 27th, 2017 at 10:59am
What Router class and RoutingOptions values are you using?
beetee
Reply #2 - Oct 27th, 2017 at 12:36pm
We are using DiagramNodeAdapter. It depends also on the source anchor point it seems.
Following are the Diagram settings
LinkRouter = new GridRouter();
RoutingOptions.Anchoring = Anchoring.Keep;
HitTestPriority = HitTestPriority.ZOrder;
BackBrush = Brushes.Transparent;
SnapToAnchor = SnapToAnchor.OnCreateOrModify;
ShowAnchors = ShowAnchors.Auto;
RouteLinks = true;
AllowSelfLoops = false;
Behavior = Behavior.DrawLinks;
AllowSplitLinks = false;
AlignToGrid = true;
LinkShape = LinkShape.Cascading;
AutoSnapLinks = true;
AutoSnapDistance = 10;
LinkHitDistance = 3;
MergeThreshold = 5;
DelKeyAction = DelKeyAction.None;
MinimumNodeSize = new Size(2, 2);
ShowDisabledHandles = false;
AllowUnanchoredLinks = false;
Selection.AllowMultipleSelection = true;
Selection.IncludeItemsIfIntersect = false;
ModificationStart = ModificationStart.SelectedOnly;
SelectionOnTop = false;
AutoResize = AutoResize.None;
and routing options
Reply #3 - Oct 27th, 2017 at 1:50pm
Our developer will check it. Are you on latest 3.5.2 version?
beetee
Reply #4 - Oct 27th, 2017 at 2:20pm
Hello Slavcho,
I have tried with 3.5.2 and its the same behavior.
Beetee
Reply #5 - Oct 30th, 2017 at 8:36am
Hello Beetee,
We've tried to reproduce with your code here but it seems to work fine -
https://mindfusion.eu/_samples/ThinNodeRouteTest.zip
Please let me know what else we should change to see the problem happen.
beetee
Reply #6 - Oct 31st, 2017 at 2:48pm
Hello Slavcho,
Please find the attached code to reproduce the issue.
Screenshot from the same code is also attached.
Thank you very much for the quick response.
Regards
Beetee
RoutingIssue.zip (Attachment deleted)
Reply #7 - Nov 1st, 2017 at 9:33am
Hi Beetee,
Right, the grid router is not handling correctly rotated DiagramNodeAdapters. Our developer is working on a fix.
Reply #8 - Nov 1st, 2017 at 9:50am
Please try this build -
https://mindfusion.eu/_temp/rotated_adapter.zip
beetee
Reply #9 - Nov 1st, 2017 at 10:44am
It works now.
Thank you very much.
beetee
Reply #10 - Nov 2nd, 2017 at 8:30am
When can we expect an official release with this fix?
Reply #11 - Nov 2nd, 2017 at 8:48am
Not in next couple of months. The assemblies above should be stable enough, we could upload them as a patched package on nuget if you don't want to deal with assembly files directly.
« Last Edit: Nov 2nd, 2017 at 9:51am by Slavcho »
beetee
Reply #12 - Nov 2nd, 2017 at 10:50am
Hello Slavcho,
I see one more issue here.
When I move the node on the right towards the vertical bar node routing is bit different. This depends on the distance between the nodes it seems. Beyond a certain distance this does not happen.
Please find the attached images before and after moving the node.
Beetee
Reply #13 - Nov 3rd, 2017 at 6:58am
Hi Beetee,
This build should fix it -
beetee
Reply #14 - Nov 3rd, 2017 at 8:58am
It works. Smiley
