Normal Topic A question about link's AutoRoute (Read 1107 times)
chowy
Nov 6th, 2017 at 7:20am
When I draw the link, set AutoRoute = true, call the Route method, some segment distance is very long, I can set the line segment distance is relatively close by the parameters? As described in the picture.
Re: A question about link's AutoRoute
Reply #1 - Nov 6th, 2017 at 7:48am
If using QuickRouter try setting its UBendMaxLen property. If using GridRouter, assign larger cost to RoutingOptions.LengthCost.
