Normal Topic Need to set image in diagram node (Read 1707 times)
Shafi
Nov 21st, 2017 at 9:12am
Hi
I have a requirement that i need to set the images in diagram node. Right now we are doing it like below code. But is there any other way so that we do not need to give URL instead we can give binary image file.
Re: Need to set image in diagram node
Reply #1 - Nov 21st, 2017 at 12:01pm
You could set as source a data URL containing base64 encoded image, like "data:image/png;base64,BASE64_ENCODED_STRING_OF_THE_IMAGE".
E.g. you could pass such string directly to setImageLocation, or set as img.src when calling node.setImage or custom drawing -
var img = new Image(); // a DOM image object
img.src = "data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAAHElEQVQI1
2P4//8/w38GIAXDIBKE0DHxgljNBAAO9TXL0Y4OHwAAAABJRU5ErkJggg==";
node.setImage(img);
// or custom drawing from updateVisuals
var image = new MindFusion.Drawing.Image(bounds);
image.image.src = "data:image..."
