Normal Topic Getting exact vertical point, i.e. y value in x-y axis, of Text in a ShapeNode (Read 1408 times)
Caerlica
Nov 21st, 2017 at 2:50pm
We use the MindFusion Diagram component to display among other things, TextNodes, which are ShapeNodes, with bindings applied to TextProperty. We can manipulate the textnode using FontSize, Vertical Alignment, and type in multiple lines of text in the same textnode.
We've built an architecture, to export the Diagram into another format, and need to calculate the exact vertical (Y) coordinate of the text in the TextNode.
I've noticed that it's extremely difficult to try to figure out a equation to calculate the vertical position, when I have to take into account the height of the shapenode, font size, text line count and vertical alignment value.
I'm wondering, if it's anyhow possible to extract the exact Y value of the Text itself, instead of the Y value of the TextNode. This way, I might be able to use the MindFusion component to give a value instead of trying to figure out a nigh-impossible equation to mathematically calculate the Y value given all the possible things.
Can you give any advice for this?
Re: Getting exact vertical point, i.e. y value in x-y axis, of Text in a ShapeNode
Reply #1 - Nov 21st, 2017 at 4:12pm
We could expose exact positions if you use the EnableStyledText or PolygonalTextLayout - the text is laid out by the diagram control then. Otherwise it's drawn using WPF's DrawingContext.DrawText method and the diagram won't know exact positions either. In both cases it should be possible to find glyph positions using VisualTreeHelper.GetChild, calling it recursively until you find GlyphRun objects.
