Normal Topic A question about undo and redo (Read 1288 times)
chowy
Dec 19th, 2017 at 8:38am
When I use diagramDraw.ActiveItem.ZTop (true);, how do I undo and restore it? Save the ZIndex property does not seem to solve the problem.
Re: A question about undo and redo
Reply #1 - Dec 19th, 2017 at 1:12pm
Try this -
void OnObjectBringToFront(object sender, RoutedEventArgs e)
	if (diagram.ActiveItem != null)
		var cmd = new BringToFrontCmd(diagram.ActiveItem);
		diagram.ExecuteCommand(cmd);
class BringToFrontCmd : Command
	public BringToFrontCmd(DiagramItem item) : base("Bring to front")
		this.item = item;
		zIndex = item.ZIndex;
	protected override void Execute(bool undoEnabled)
		item.ZTop(true);
	protected override void Undo()
		item.ZIndex = zIndex;
	protected override void Redo()
		item.ZTop(true);
	DiagramItem item;
	int zIndex;
