Normal Topic 1) Node move as per scrolling. (Read 2185 times)
Shafi
Dec 27th, 2017 at 6:51am
We need to create node in such way that, it will move as per scrolling the diagram.
Image1.png:  Initial diagram in which Node: 1 has set above property.
When we scroll-down the diagram then Node: 1 position changes as per scolling.
How to achieve this?
Re: 1) Node move as per scrolling.
Reply #1 - Dec 27th, 2017 at 8:06am
There's Diagram.onScroll member function called when users scroll, you could inject your code there to move some nodes -
var scrollHandler = Diagram.prototype.onScroll;
Diagram.prototype.onScroll = function()
    scrollHandler.apply(this);
    fixedNode.setBounds(...);
Shafi
Reply #2 - Jan 3rd, 2018 at 2:04pm
This code not working a t my side.
I am using angular 2 to develop my application.
Lyubo
MindFusion team
Reply #3 - Jan 4th, 2018 at 7:06am
You can use the module augmentation technique in TypeScript to expose the private onScroll member to your API. Like this:
Code (Javascript)
declare module MindFusion.Diagramming
    interface Diagram
        onScroll(): void;
// now onScroll can be overriden in code like in the example above
Lyubo
