Normal Topic How to customize the save file? (Read 1964 times)
Gu Wenwei
Dec 29th, 2017 at 1:33pm
A part of a custom savefile
Online
Re: How to customize the save file?
Reply #1 - Jan 2nd, 2018 at 9:28am
If using binary format, you could call Diagram.SaveToStream method to store the diagram as part of your own file. Alternatively store your data as a serializable Diagram.Tag object and SaveToFile will save it as part of the diagram file.
If using XML format, you could call Diagram.SaveToXml (XmlDocument) to save the diagram in an in-memory document, and then either move the root element to your own document, or add your own elements to the diagram's document.
Another option is to make your files zip archives and store diagrams' and your custom data separately inside.
Gu Wenwei
Reply #2 - Jan 3rd, 2018 at 12:29pm
THX;
now, i use SaveToString (SaveToStringFormat.Base64),  then process the string
