Normal Topic Disable moving of diagramnodse to a certain direction (Read 2037 times)
tjugg
Jan 16th, 2018 at 6:42am
I have a situation where I select multiple DiagramNodes by dragging, and move them all to another position.
Problem is, if I drag them to the edge of the canvas, the nodes will go on top of each other, following the mouse
movement over the canvas. Is there any way to
completely disable moving of a node? Something like checking if the nodes bounds are close to the bounds of the canvas,
disable moving of all selected nodes to that direction (node is close to the right left border, now only allow to move the group to the right)?
Re: Disable moving of diagramnodse to a certain direction
Reply #1 - Jan 16th, 2018 at 9:24am
This when using the KeepInsideDiagram flag? We'll try implementing a similar property for the Selection object, so it stops when selection's bounding rectangle touches diagram's edges.
It could be also possible to stop movement by implementing a custom Behavior class. E.g. defer to base in most cases but do not call base.OnMouseMove if you detect original selection bounds + mouse position offset would move beyond diagram edges.
tjugg
Reply #2 - Jan 19th, 2018 at 11:20am
Hi, yes it's when using the KeepInsideDiagram flag.
Reply #3 - Feb 26th, 2018 at 9:33am
This build adds Selection.KeepInsideDiagram property-
https://mindfusion.eu/_beta/wpfdiag353.zip
