Normal Topic Onnodeclicked event and error while compiling (Read 4542 times)
TechNerd
Jan 17th, 2018 at 7:22am
Hi ,
I'm quite new here. Can someone help me regarding this issue:
1.) I'm facing difficulty onnodeclicked event. It will fired when first node is selected, then click on another node without deselect the first one, onodeclicked event not triggered for the second node. - using javascript
2) Sometime when I'm publishing my code, there's error stated that diagram does not declared. But when I click on stated error, there's nothing wrong in my code. I have to close the project and reopen again to compile it. Why such thing happen?
Re: Onnodeclicked event and error while compiling
Reply #1 - Jan 17th, 2018 at 8:04am
1) Check if it isn't showing some JavaScript errors in browser's console.
2) No idea. What Visual Studio, diagram control and .NET versions are you using?
TechNerd
Reply #2 - Jan 17th, 2018 at 10:07am
Thanks for the prompt reply.
1) There's no javascript error in browser console
2)Visual studio 2015 and .net 4.0.
Reply #3 - Jan 17th, 2018 at 11:40am
Please attach a test project that reproduces the problems.
