Normal Topic How to differentiat drag and node click (Read 6728 times)
reshma
Jan 17th, 2018 at 12:52pm
I am stuck on how can we drag and node click at a time in mindfusion is there any other event or provision to differentiat that both event?
Online
Re: How to differentiat drag and node click
Reply #1 - Jan 17th, 2018 at 1:45pm
There are nodeModified and nodeClicked events raised respectively when you move a node or click it. If you are asking for a way to drag a node without having to click-select it first, you can enable that by setting Diagram.setModificationStart(ModificationStart.AutoHandles);
reshma
Reply #2 - Jan 19th, 2018 at 8:52am
not worked for me
Online
Reply #3 - Jan 19th, 2018 at 3:43pm
What's not working exactly, the control's not calling your event handler functions?
reshma
Reply #4 - Jan 22nd, 2018 at 6:46am
yes control not calling double click event
Online
Reply #5 - Jan 22nd, 2018 at 7:31am
The event is raised as expected for me. Have you subscribed to it by calling addEventListener?
var Events = MindFusion.Diagramming.Events;
diagram.addEventListener(Events.nodeDoubleClicked, onNodeDoubleClicked);
What kind of nodes are you using in the diagram?
reshma
Reply #6 - Jan 24th, 2018 at 11:06am
i have added event listener in same way,
still it is not working in angular 2
Online
Reply #7 - Jan 24th, 2018 at 11:37am
Are you on same team as Shafi? I remember that particular Angular 2 application was calling diagram.setEnabled(false) at some point, which disables all mouse processing including handling of double clicks.
