Normal Topic How to prevent links overlapping between two shape nodes (Read 2743 times)
ashar11
Jan 17th, 2018 at 1:00pm
    When I create links between two shape nodes the links start overlapping on first link, how can i give a little distance between them so I can distinguish among them.
Re: How to prevent links overlapping between two shape nodes
Reply #1 - Jan 17th, 2018 at 1:34pm
Try the method from this post -
https://mindfusion.eu/Forum/YaBB.pl?num=1374661504/1#1
ashar11
Reply #2 - Jan 26th, 2018 at 12:39pm
I have tried this solution you provided given in the link, but the issue is when i user PullLinksApart(2) with the padding it also moves my anchor point whether its on point X or Y.What i needed is, after i create the links between two nodes and then i move one of the node from them the it creates the gap among links automatically which is perfect and happening right now. So how can I implement the same effect. I have attached the pic below.
Reply #3 - Jan 29th, 2018 at 8:21am
If you like what you get after moving a node, I guess it's the result of automatic link routing, or of running some code in NodeModified event handler. There's a slight difference in how the AutoRoute property works when you create or modify a single link - it does not consider other links, while moving a node or calling diagram.RouteAllLinks will consider all links together and pull them apart internally. So try calling diagram.RouteAllLinks() after creating all nodes and links.
ashar11
Reply #4 - Jan 29th, 2018 at 8:37am
Yes after using diagram.RouteAllLinks() in linkcreated funtion its working as i needed.
