Normal Topic How to have TemplatedNode auto size to content (Read 1496 times)
notsureusa
Mar 8th, 2018 at 1:02pm
I've created a custom TemplatedNode that has contents with varying widths and heights and want the bounds to be different for each node.  How can one accomplish this?
Lyubo
MindFusion team
Re: How to have TemplatedNode auto size to content
Reply #1 - Mar 8th, 2018 at 2:42pm
If you're using a custom class inheriting TemplateNode, you can add the following method, which can be used to resize the node according to it's contents:
public void ResizeToFit()
        var child = GetVisualChild(0) as UIElement;
        if (child != null)
            child.Measure(new Size(double.PositiveInfinity, double.PositiveInfinity));
            var childSize = child.DesiredSize;
            SetBounds(new Rect(Bounds.Left, Bounds.Top, childSize.Width, childSize.Height), true, true);
You can call this method after creating the node, if you're using a static template, or in response to a value changed handler, if you are using a template with bound fields.
Lyubo
