Normal Topic Can we add a URL to node? (Read 1555 times)
Shafi
Mar 26th, 2018 at 1:11pm
I have a query regarding how we can add a URL to node text, on-clicking of the text we should be able to redirect to the given URL, is it possible?
Thanks & Regards,
Prasad
Online
Re: Can we add a URL to node?
Reply #1 - Mar 26th, 2018 at 1:22pm
If whole text should act as a hyperlink you could redirect to the URL from nodeClicked event handler. If you need links embedded among other text, try version from this post -
https://mindfusion.eu/Forum/YaBB.pl?num=1511512419/29#29
« Last Edit: Mar 26th, 2018 at 7:01pm by Slavcho »
