Normal Topic How to update image of node on mouse hover event? (Read 1488 times)
Shafi
Apr 16th, 2018 at 11:34am
I have added image inside node and I want this image should appear bigger or highlight on mouse hover on it.
How to do this?
Lyubo
MindFusion team
Re: How to update image of node on mouse hover event?
Reply #1 - Apr 16th, 2018 at 1:28pm
One thing you can do is handle the diagram canvas' mousemove event and hit-test for a node under the cursor. If you detect a node, you can then further test if the cursor is above the image in question, using the technique from this post. When you detect the image, you can then set a local variable to the pointed node, which can be used inside your onUpdateVisuals callback to increase the bounds of the image.
Code (Javascript)
var pointedNode = null;
$("#diagram").bind("mousemove", (e) =>
  let node = getNodeUnderCursor(e);
  if (node != null)
    var content = node.getGraphicsContent();
    var image = content[content.length - 1];
    if (contains(image.bounds, getLocalPoint(e)))
      pointedNode = node;
    else
      pointedNode = null;
    (node as MindFusion.Diagramming.DiagramNode).invalidate();
    return;
  pointedNode = null;
function getNodeUnderCursor(event)
  var localPoint = this.getLocalPoint(event);
  return this.diagram.getNodeAt(localPoint, true, true);
function getLocalPoint(event)
  var offset = $('#diagram').offset();
  var x = (event.pageX - offset.left) + $(window).scrollLeft();
  var y = (event.pageY - offset.top) + $(window).scrollTop();
  return this.diagram.clientToDoc(new MindFusion.Drawing.Point(x, y));
function inflate (rect, x, y)
  if (rect.width + 2 * x < 0)
    x = -rect.width / 2;
  if (rect.height + 2 * y < 0)
    y = -rect.height / 2;
  return new Rect(rect.x - x, rect.y - y, rect.width + 2 * x, rect.height + 2 * y);
function onUpdateVisuals(item)
  var imageRect = new Rect(rect.x + 20, rect.y + 20, 10, 10);
  if (pointedNode == item)
    imageRect = inflate(imageRect, 2, 2);
  var image = new MindFusion.Drawing.Image(imageRect);
Lyubo
