Normal Topic ScaleToPage print options (Read 12452 times)
JR
Apr 25th, 2018 at 10:15am
I have a problem with the ScaleToPage print option.
If the diagram is little, it works, but when it is a big diagram, it does not work.
Is there a limit ?
My diagram zipped takes 650kb so I can't sent it to you.
How do I know if the diagram can fits in one page?
Best regards
Re: ScaleToPage print options
Reply #1 - Apr 25th, 2018 at 11:37am
What are your diagram's top/left/right/bottom boundaries and MeasureUnit?
JR
Reply #2 - Apr 25th, 2018 at 12:32pm
Measureunit = 2 (pixel)
top = 0
bottom = 24359
left = 0
right = 157213
Regards
Reply #3 - Apr 26th, 2018 at 8:06am
fcx.MeasureUnit = uPixel
fcx.SetDocSize 0, 0, 157213, 24359
fcx.PrintOptions.ScaleToPage
above fits it on a single page in my test -
ScaleToPage only calculates a current PrintOptions.ScaleFactor value and does not update it automatically later, so maybe check if the diagram size isn't growing at some point after you call the method.
JR
Reply #4 - Apr 26th, 2018 at 8:14am
The diagram does not grow.
I saved my graph with tour SaveToFile method.
When I load this file in you run demo application, I have the same problem when i click in Fit Page in the Print preview window.
Regards
Reply #5 - Apr 26th, 2018 at 10:28am
What's your printer's default paper size?
JR
Reply #6 - Apr 26th, 2018 at 10:34am
A4.
If I put the A0 format. It works.
I know that the display will be ugly, but the user will see that the printing of this graph in a single page will not be exploitable.
In fact, the problem is that the function does not work for large graphs. The graph remains the same as before fitting the page.
I would like to show him an error message if it's not good.
Here are the 3 files (remove .txt at the end of the filename) and use 7-zip on the .001 file
« Last Edit: Apr 26th, 2018 at 12:36pm by JR »
essai_zip_001.txt (Attachment deleted)
essai_zip_002.txt (Attachment deleted)
essai_zip_003.txt (Attachment deleted)
Reply #7 - May 1st, 2018 at 12:15pm
It actually calculates a ScaleFactor value close to zero for this graph, and since the property is of integer type the setter receives a truncated 0 value and refuses it -
STDMETHODIMP PrintOptions::ScaleToPage()
	put_ScaleFactor(SHORT(100 * ratio));
STDMETHODIMP PrintOptions::put_ScaleFactor(SHORT newVal)
	if (newVal > 0)
The FP value is 0.533210039, which would print a pixel per 200-pixel large box, and that won't show anything legible anyway. I guess you could check if ScaleFactor remains unchanged by ScaleToPage() when the document is very large and show warning to user that it can't fit on a page.
JR
Reply #8 - May 2nd, 2018 at 7:45am
Ok.
Regards
