Normal Topic Copy and Paste - Node (Read 3728 times)
Kuzya
Jun 7th, 2018 at 9:52pm
Hi Lyubo,
how does copying and pasting elements?
Tutorial4(Tutorial 4: Custom Nodes Integration) is not working Sad
Kuzya
Lyubo
MindFusion team
Re: Copy and Paste - Node
Reply #1 - Jun 11th, 2018 at 5:25am
Tutorial4 is working as expected in my test. Which browser are you using? Are there any errors shown in the browser's console window?
Lyubo
Kuzya
Reply #2 - Jun 11th, 2018 at 7:48am
Hi Lyubo,
browser - Firefox
Errors - Tutorial4.html:15 Uncaught TypeError: diagram.copyToClipboard is not a function
    at HTMLButtonElement.onclick (Tutorial4.html:15)
Kuzya
Lyubo
MindFusion team
Reply #3 - Jun 11th, 2018 at 8:04am
Can you verify that the diagram is actually loaded and interactive? Can you draw nodes/links on the canvas, and does the NodeListView display nodes?
In the case of this sample, ''diagram'' is a variable for easy access to the diagram control, but also the name of the canvas html element. You can try accessing the diagram object like this:
Code (Javascript)
var d = MindFusion.Diagramming.Diagram.find("diagram"); // diagram is the id of the canvas html element.
if (d == null)
    alert('diagram is not loaded');
else
    d.copyToClipboard(); // should copy the selection to clipboard.
Does the above work in your case?
Lyubo
Kuzya
Reply #4 - Jun 15th, 2018 at 11:37am
Hi Lyubo,
I need to copy selected elements and edges.
Kuzya
Lyubo
MindFusion team
Reply #5 - Jun 18th, 2018 at 5:28am
The copyToClipboard method copies all selected items to the clipboard. You can add items to the selection by using DiagramItem.setSelected(true), or via the Diagram.getSelection() property.
Lyubo
Kuzya
Reply #6 - Aug 6th, 2018 at 8:33am
we try to copy an element from one diagram to another tab.
Apparently this is not possible via the system clipboard.
Is there a workaround for this?
Kuzya
Online
Reply #7 - Aug 6th, 2018 at 10:52am
With the sytemClipboard argument enabled, the control will assign the data to window.clipboardData object. That used to work between tabs at some point, but now seems disabled - probably because of security concerns. If you set the argument to false, copied data is saved as json in window.mf_clipboard field - you could try saving its value in browser's local storage to access from other tabs, and read from local storage just before calling paste.
Kuzya
Reply #8 - Aug 7th, 2018 at 6:23am
Thanks for the answer, this works great.  Smiley
But I have another problem: I would like to paste the copied element at the cursor position. Is that possible?
Apparently, the position to be specified always depends on the original element.
Kuzya
Online
Reply #9 - Aug 7th, 2018 at 8:58am
The only control you have over position is via the offset arguments of pasteFromClipboard method, where offsets are relative to original items' positions. You could save x/y coordinates of diagram.selection.bounds in your local-storage clipboard as well, and then specify offsetX/Y as the difference between wanted position and saved selection position when pasting -
d.pasteFromClipboard(cursorX - savedX, cursorY - savedY);
