Normal Topic Large Diagrams (Read 1497 times)
Bertrand
Large Diagrams
Jun 17th, 2018 at 9:58pm
We use the WPF diagram. We try to display large diagrams showing the links between optical splitters.
As you can see in the following samples in attachments, we are limited by a box (certainly the drawing area).
Do you have an idea to increase the box in order to have a better rendering ?
Best regards,
Re: Large Diagrams
Reply #1 - Jun 18th, 2018 at 7:15am
How do you build these diagrams? Force-directed layout classes have a LayoutArea property you could try setting to a larger value. For other classes, set larger layer/node distance values, and then call ResizetoFitItems after layout.Arrange.
Bertrand
Re: Large Diagrams
Reply #2 - Jul 13th, 2018 at 7:25am
Thank you. I work with the parameters of the layout and it works fine.
