Hot Topic (More than 10 Replies) UI controls for Winforms? (Read 8778 times)
MarkAGr
New to it all, really
frustrating at the moment.
Jul 2nd, 2018 at 8:02am
Hi, where to I put questions/bug reports for UI.Controls for Winforms?
In the meantime, I'll leave the question here ... I've been having a problem with ItemActive event ... this only appears to be triggered when the tab or titlebar is clicked ... it's not triggered when the content of the window is clicked in and changed (the titlebar/frame changes colour - BUT no ItemActive is triggered. - Is this a BUG or am I doing somthing stupid?)
8^)
Mark
MarkAGr
Re: UI controls for Winforms?
Reply #1 - Jul 2nd, 2018 at 9:21am
Oh, and is there an event when a dockItem is deActivated ?
MarkAGr
Reply #2 - Jul 2nd, 2018 at 2:28pm
And ... if I select a none-tabbed item ... then select the top/currently exposed tabbed item ... I get two ItemActivated messages ... is this normal behavior?
It'll save a lot of execution if it occurs only once!
Online
Reply #3 - Jul 3rd, 2018 at 6:53am
Here's a new forum board for Windows Forms controls. Our developer will check the activation events.
MarkAGr
Reply #4 - Jul 3rd, 2018 at 9:35am
Thanks Smiley
Online
Reply #5 - Jul 5th, 2018 at 8:41am
This build adds ItemDeactivated event and should raise activated one more consistently -
https://mindfusion.eu/_beta/winforms_dock_events.zip
MarkAGr
Reply #6 - Jul 5th, 2018 at 9:06am
Thank You .... but what do I do with the zip-file?
MarkAGr
Reply #7 - Jul 5th, 2018 at 9:45am
OK, Thanks ... I worked it out.
MarkAGr
Reply #8 - Jul 5th, 2018 at 7:23pm
Is it possible to have an active dockItem to cause an ItemDeactivated event before it is closed?
Online
Reply #9 - Jul 6th, 2018 at 10:37am
We'll try to implement that in next couple of days.
MarkAGr
Reply #10 - Jul 6th, 2018 at 11:39am
Thank you
8^)
Online
Reply #11 - Jul 10th, 2018 at 9:36am
New build here should raise deactivated event before closed one -
MarkAGr
Reply #12 - Jul 10th, 2018 at 3:06pm
Thanks you very much!
