Normal Topic BarChart Layout Bug in Charting.WinForms (Read 8774 times)
nstid
Jul 12th, 2018 at 9:24pm
I do not know if this is known yet, but if you load a bar chart's series by binding it with a data table and selecting the fields, you cannot set the chart's bar layout as a stack unless there is data in the bound table.
If you use any other layout, the chart works as expected and simply displays an empty chart. But with the stack layout, the chart becomes covered by a red x and eventually enters a break mode with the following error:
System.ArgumentOutOfRangeException
HResult=0x80131502
Message=Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
Source=mscorlib
StackTrace:
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.Collections.Generic.List`1.get_Item(Int32 index)
at MindFusion.Charting.BarStackRenderer.c746ac75bf9a7cad6bbb598cbd261d82c(RenderCon
text c6d5eeb65a8110234bb147969b433b549)
at MindFusion.Charting.BarStackRenderer.EnumVisibleStackBars(RenderContext context, ProcessStackBars process)
at MindFusion.Charting.BarStackRenderer.HitTest(RenderContext context, PointD location)
at MindFusion.Charting.WinForms.Dashboard.cac2b74b6ff76fdd5cde3eed24cde0f40(PointF cc7f0988578730f8a6754c2a6ba358f36, Plot c7ef9d835f5358bd3f0b1317c59e49509)
at MindFusion.Charting.WinForms.Dashboard.HitTest(PointF location)
at MindFusion.Charting.WinForms.Dashboard.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNat
iveMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicat
ionModel()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String
[] commandLine)
at ReportGenerator_v2.My.MyApplication.Main(String[] Args) in :line 81
Re: BarChart Layout Bug in Charting.WinForms
Reply #1 - Jul 17th, 2018 at 1:19pm
In our test it worked correctly with empty table if we still set the fields values - then it adds empty series to the chart and draws an empty plot. It did crash when we hadn't assigned any fields (leading to no series being created), which should be fixed here -
https://mindfusion.eu/_temp/chart_index.zip
nstid
Reply #2 - Jul 17th, 2018 at 5:02pm
Awesome, thank you!
