Hot Topic (More than 10 Replies) How might one maximise/minimise/restore a floating DockItem ? (Read 10745 times)
MarkAGr
New to it all, really
frustrating at the moment.
Aug 2nd, 2018 at 8:31pm
I was hoping to add a button to the frame ... ( can't )
or catch a double click on the title bar ... ( can't )
then call a maximise/maximise/restore method ... ( can't )
but alas ... none of those appear possible ...
8^(
Mark
Online
Re: How might one maximise/minimise/restore a floating DockItem ?
Reply #1 - Aug 6th, 2018 at 5:05pm
You can get a reference to a DockItem's container like this -
item.Content.ParentChanged += ContentParentChanged;
void ContentParentChanged(object sender, EventArgs e)
	var control = sender as Control;
	var parent = control.Parent as Control;
	if (parent != null)
		var btn = new System.Windows.Forms.Button { Text = "+" };
		parent.Controls.Add(btn);
		btn.BringToFront();
		// how do we move this to titlebar?
Problem is when DockItem is in floating state, its container is a standard Form object and the added child control goes in form's client area below title bar, and not inside the bar. We'll look for some way to allow customizing it in next few days.
MarkAGr
Reply #2 - Aug 11th, 2018 at 2:23pm
Thank You ... much appreciated Smiley
MarkAGr
Reply #3 - Aug 21st, 2018 at 4:39pm
Any advances?
MarkAGr
Reply #4 - Aug 31st, 2018 at 8:15pm
Any Luck Yet?
Online
Reply #5 - Sep 4th, 2018 at 8:18am
Our developer is working on it.
MarkAGr
Reply #6 - Sep 4th, 2018 at 4:49pm
(y) (y) Thanks Guys!
Online
Reply #7 - Sep 10th, 2018 at 9:59am
Try this build -
https://mindfusion.eu/_beta/dock_tbar_buttons.zip
It adds a TitleBarButton class and three list properties used as titlebar templates,  where you can add buttons depending on the dock-item state: DockedTitleBarButtons, UndockedTitleBarButtons, TabbedTitleBarButtons. You can add a custom button like this -
var myTitleButton = new TitleBarButton();
myTitleButton.ButtonPen = new Pen(Color.Red);
myTitleButton.ButtonImage = Image.FromFile(...);
//myTitleButton.Draw += MyTitleButton_Draw;
myTitleButton.OnClick += MyTitleButton_OnClick;
dockControl1.DockedTitleBarButtons.Add(myTitleButton);
private void MyTitleButton_OnClick(object sender, MouseEventArgs e)
  MessageBox.Show("Custom button clicked", "Custom", MessageBoxButtons.OK);
private void MyTitleButton_Draw(object source, DrawEventArgs e)
  var tbb = source as TitleBarButton;
  if (tbb == null)
    return;
  e.Graphics.DrawArc(tbb.ButtonPen, new Rectangle(tbb.X, tbb.Y, tbb.Width, tbb.Height), 0, 360);
MarkAGr
Reply #8 - Sep 10th, 2018 at 1:40pm
Ooooh nice!
I'm going to need some time to mull over these.
Thank You Smiley
MarkAGr
Reply #9 - Sep 11th, 2018 at 8:52am
Hi ...
There appears to be just one or two minor problems ...
1) an exception is caused if there's nothing attached to the click event
There should be an event attached to the button - so that's not really a hardship -
2) the click event triggers whether the mouse is over the button or not when the button is released.
On checking, this might be the mindfusion standard way of doing it ... I was under the impression that a click event isn't activated if the cursor is no longer over the button when the mouse button is lifted. - I could be wrong.
8^)
Mark
Online
Reply #10 - Sep 12th, 2018 at 10:11am
New build here should fix that -
MarkAGr
Reply #11 - Sep 13th, 2018 at 12:10pm
Wey hey! This works gr8!
Thanks!!!
8^)
Mark
