Normal Topic Flip Node derived from DiagramNodeAdapter (Read 1609 times)
benjamin huser
Aug 21st, 2018 at 3:01pm
Hi
we have a requirement that we should allow our nodes that are displayed to be flipped horizontally and/or vertically.
I saw in the docs that this seems possible for ShapeNodes (https://www.mindfusion.eu/onlinehelp/wpfdiagram/index.htm) but our implementation is deriving from the DiagramNodeAdapter where I could not find any flip related property like AllowFlip, FlipX and FlipY.
Did I miss the respective properties or is this currently not possible?
Best Regards
Benjamin
Re: Flip Node derived from DiagramNodeAdapter
Reply #1 - Aug 23rd, 2018 at 6:23am
Properties are only available for ShapeNodes and they apply only to the shape geometries.
If you need to flip all graphic elements of adapted components, you can implement it easily by setting -1 horizontal or vertical scale through their RenderTransform. If you need it only for some parts (say keep text and icons in straight direction), you might have to reorganize your components a bit. E.g. create flippable-graphics container for some graphics elements and unflippable one, and apply the scale transform on former.
If you need to let users flip interactively, you will have to override the UpdateModify method. The ShapeNode implementation does this -
base.UpdateModify(current, ist);
if (allowFlip && ist.AdjustmentHandle.IsResizeHandle() &&
	ist.OriginalStates.ContainsKey(this))
	var state = (ShapeNodeState)ist.OriginalStates[this];
	bool oldFlipX = flipX;
	bool oldFlipY = flipY;
	flipX = ist.negativeWidth ?
		!state.FlipX : state.FlipX;
	flipY = ist.negativeHeight ?
		!state.FlipY : state.FlipY;
	if (flipX != oldFlipX || flipY != oldFlipY)
		UpdateShapePoints();
