Normal Topic Get Node and the connected Node (Read 1792 times)
mohamed
Sep 9th, 2018 at 11:05am
Hi
How to get specified Node And get the other Node connected to it and display the in new diagram
Re: Get Node and the connected Node
Reply #1 - Sep 10th, 2018 at 10:26am
If you need to do that on server side, you could query the diagram.Nodes collection using Linq by whatever criteria you want to apply. Then you can follow node's links to find respective origin and destination nodes -
var node = diagram.Nodes.Where(...).FirstOrDefault();
foreach (var outLink in node.GetAllOutgoingLinks())
	Debug.WriteLine(outLink.Destination.Id);
foreach (var inLink in node.GetAllIncomingLinks())
	Debug.WriteLine(inLink.Origin.Id);
