Normal Topic Change Button Actions (Read 2586 times)
Davaaron
Sep 11th, 2018 at 1:48pm
how can I bind Panning to the left button and creating new nodes to ALT + left button and keep the CTRL + left for selecting multiple nodes?
(Is there any way I can select nodes which are not detected by the CTRL + left like children of containernodes?)
Thanks in advance.  Smiley
Re: Change Button Actions
Reply #1 - Sep 11th, 2018 at 4:57pm
You can do that by creating a custom BehaviorBase-derived class and assigning its instance to diagram.currentBehavior field, or just replace createController method of default behavior class like this -
var mdiag = MindFusion.Diagramming;
diagram.getModifierKeyActions().setAlt(
	mdiag.ModifierKeyAction.None);
var createController = mdiag.LinkNodesBehavior.prototype.createController;
mdiag.LinkNodesBehavior.prototype.createController = function (state)
	var diagram = this.diagram;
	var kb = mdiag.Keyboard.state;
	if (kb.altKey)
		return createController.apply(this, [ state ]);
	if (kb.ctrlKey)
		return new mdiag.CreateSelectionController(diagram.selection);
	return new mdiag.PanController(diagram);
The Selection class runs its selectItemsInRect(rect) method when you stop drawing selection lasso, so you could replace Selection.prototype.selectItemsInRect with your own version that calls item.setSelected(true) for the items you want selected.
Davaaron
Reply #2 - Sep 11th, 2018 at 6:00pm
The following types do not exist
  1. Keyboard
  2. CreateSelectionController
  3. PanController
  4. LinkNodesBehavior
in typescript. Um, are there equivalents?
Lyubo
MindFusion team
Reply #3 - Sep 12th, 2018 at 12:56pm
We will add those to the definitions file in the following days.
Lyubo
Lyubo
MindFusion team
Reply #4 - Sep 17th, 2018 at 1:39pm
Please find attached the updated definitions file.
Lyubo
jsdiag_d_ts.zip (Attachment deleted)
Davaaron
Reply #5 - Sep 19th, 2018 at 7:06am
Thanks  Smiley
