Normal Topic Change default Shape Type when drawing or creating a node (Read 2471 times)
Davaaron
Sep 13th, 2018 at 2:03pm
I saw that the LinkNodeBehavior calls the constructor of the ShapeNode. Whenever I draw a node or drop a node from the list view into the Diagram, I'd like to create a ContainerNode instead.
How could I achieve that?
Re: Change default Shape Type when drawing or creating a node
Reply #1 - Sep 14th, 2018 at 8:48am
What instance is created when you draw with mouse depends on diagram.Behavior property value; try setting it to either DrawContainers or LinkContainers. As for "drop a node from the list view" part, it just clones whatever node instance you drag from the list, so add an actual ContainerNode there.
Davaaron
Reply #2 - Sep 14th, 2018 at 11:55am
When I do that when listening on mousedown event, don't I interrupt the creation of controllers within the Behavior.createController?
If mousedown=true, wouldn't I need to distinguish between moving nodes or selecting them and drawing?
I created my own list view because I want to stay independent here.
Edit: Drawing a container node now works.
But somehow panning doesn't work. I even enable it setting Behavior.Pan. What could cause this issue? The canvas is offsetLet and Top but has a width of more than 4000px and height near to 3000px.
Reply #3 - Sep 14th, 2018 at 2:53pm
Have you enabled overflow on the div that contains diagram's <canvas> element? Other than that, try adding a breakpoint on the 'return new PanController' line in your custom behavior code to verify if it's ever hit.
Davaaron
Reply #4 - Sep 17th, 2018 at 2:47pm
Yea I set it to true (scroll). I removed my custom behavior for now to avoid side effects.
